Case 1030 sleeves
Lanse
08-22-2007 11:09:06
I didd'nt post the following, Dairy Farmer in WI did, on the tractor talk board. I thought you guys could help him:
is it common on the 1030 that the sleeves go bad? i have a feeling i have to replace the sleeves on it. thought it was a head gasket but a mechanic thinks the sleeves are junk. how common is this? the old head gaskets are fairly new. do i have toher problems? i have water in the oil. i know it's not the block because i had that checked before.
thanks
DF in WI
casetractor700
08-24-2007 09:42:15
 Re: Case 1030 sleeves in reply to Lanse, 08-22-2007 11:09:06
my granfather has an early 1030 and it has broken the sleeves several a couple of times at the flange. a friend said tha some of the earlier blocks would kinda settle a little( not exactly the right description but it works) around the area between the sleeves in flange bore. install your old sleeves and measurethe protrusion above the block surface. i dont know the spec but i know that it will be alittle bit above this keeps sleeve held down tight against the counter bore. if there is no protrusion the sleeves will workup and down. you could also measure the depth of the bore and see if there is a low area this will lead to cracking also. casemay still offer shims to remedy that but the block will have to be machined. hope this helps
Roger (Mi)
08-23-2007 16:31:02
 Some Case 1030 sleeves have a flaw in reply to Lanse, 08-22-2007 11:09:06
There is a stress relief groove directly under the sleeve flange. If that is square cut groove, the sleeve will develop a crack in the corner of that groove. Then compression will leak into the cooling system and antifreeze will leak into the cylinder. Other sleeves are NOT square cut. The groove is a radius cut. There is no place for a crack to start. Sorry, don't recall if the good sleeves are TRW or Sealed Power.
jim handke
08-24-2007 05:46:35
 Re: Some Case 1030 sleeves have a flaw in reply to Roger (Mi), 08-23-2007 16:31:02
Dad and I both had 1030's that had sealed power sleeves installed. I still have an 830 with them in. Nary a problem with any of them.
