high/low ranges
Roger (Mi)
07-27-2007 05:17:02
The lever coming through the floor is for the high/low range selection. High range is seldom used. The high range is only useful if the crawler is be driven to another job near the same job site. Using the high range lowers engine RPM and will save some fuel. Obviously, the crawler will move faster too. Track tightness: Put a pry bar near a top roller and pry up. There should be at least a one inch gap between the track rail and roller. If there are two inches or more, it needs tightening.
Dave Mckee
07-28-2007 20:17:44
 Re: high/low ranges in reply to Roger (Mi), 07-27-2007 05:17:02
Thanks for the info, I assume that low is when the lever is towards the rear of the machine.
