Case 450D crawler questions
Dave Mckee
07-26-2007 19:36:33
I recenly bought a case 450D, I believe a 1967 model. Was wondering what the lever that runs through floor below forward and reverse levers is used for? I cannot move mine or have not figured out the trick.
Also wondered if there is a measurement for track tightness.
Roger (Mi)
07-27-2007 05:17:02
 high/low ranges in reply to Dave Mckee, 07-26-2007 19:36:33
The lever coming through the floor is for the high/low range selection. High range is seldom used. The high range is only useful if the crawler is be driven to another job near the same job site. Using the high range lowers engine RPM and will save some fuel. Obviously, the crawler will move faster too. Track tightness: Put a pry bar near a top roller and pry up. There should be at least a one inch gap between the track rail and roller. If there are two inches or more, it needs tightening.
Dave Mckee
07-28-2007 20:17:44
 Re: high/low ranges in reply to Roger (Mi), 07-27-2007 05:17:02
Thanks for the info, I assume that low is when the lever is towards the rear of the machine.
