I just did a 430 PS problem
bjr
07-20-2007 07:06:26
The 430 gas tractor pump was mounted to right front of engine and was gear drive off the cam gear of the engine. The drive gear on the pump had shearded the key and was just spinning on the shaft. My pump was junk,it had been run dry to many times. The tractor had the control valve on the cylinder down under the radiator. Long story made short, I replace pump with a old ford pickup PS pump belt drive mounted it on the left side of engine and it worked great. Check your system to make sure pump is putting out. bjr
smcelhe
07-20-2007 07:45:00
 Re: I just did a 430 PS problem in reply to bjr, 07-20-2007 07:06:26
Thanks for the info....
The pump is gear drive and apprears to be working...he"s taken the lines off the cylinders and the pumped sprayed fluid.
I guess that doesn"t mean the pump is putting out enough pressure....
Any other things to check?
Shawn
