Either packing or secondary relief
Roger (Mi)
07-19-2007 05:26:59
There is a secondary relief BETWEEN the valve spool and the hydraulic roll-back cylinders on the loader! If you're using the loader bucket in the dump position to level, there is protection from causing damage to the loader if a large obstacle is hit. While you may want to check that out, your problem is more likely internal piston seals. Case industrial dealers will have kits.
joe francano
07-19-2007 20:19:38
 Re: Either packing or secondary relief in reply to Roger (Mi), 07-19-2007 05:26:59
Thanks for the information.
I am thinking of trying the seal kits from Equipment Parts in Casper, WY. Will they be the same quality as the ones from Case themself?
Thanks.
Roger (Mi)
07-20-2007 03:50:09
 Have had good luck with aftermarket kits in reply to joe francano, 07-19-2007 20:19:38
I've used aftermarket seal kits, and they work as well as the Case kits. Case is very competitive on their seal kits and hydraulic pumps. Since I have a Case industrial dealer within 20 miles (South Bend), I buy most of my backhoe parts there.
