580ck B bucket losing strength
joe francano
07-18-2007 05:05:57
Hello,
I have been doing some heavy lifting with my front bucket on my 580 CK "B" model tractor. I have the backhoe attachment on it. The problem is the curl of the front bucket will sometimes not curl up and suddenly slam down. There are no external leaks, so I am not sure exactly what to start with to stop the problem. I am guessing something in the valve that moves the front bucket. I also am guessing that there is some sort of rebuild kit for it. Thanks for any information.
Dennis/Ohio
07-20-2007 04:30:14
 Re: 580ck B bucket losing strength in reply to joe francano, 07-18-2007 05:05:57
The control valve doesn"t have seals inside. The spool valves are a machined fit. Each spool valve has seals at the ends only. I"ll guess one bucket cylinder is bypassing internaly. One bad cylinder would effect both bucket cylinders. The secondary relief valve is something you"ll want to understand better to diagnose some problems or maybe this one? If it works OK sometimes, I"d be thinking more about the secondary relief valve. Service manuals are a great investment.
Best wishes, Dennis..... ...
Roger (Mi)
07-19-2007 05:26:59
 Either packing or secondary relief in reply to joe francano, 07-18-2007 05:05:57
There is a secondary relief BETWEEN the valve spool and the hydraulic roll-back cylinders on the loader! If you're using the loader bucket in the dump position to level, there is protection from causing damage to the loader if a large obstacle is hit. While you may want to check that out, your problem is more likely internal piston seals. Case industrial dealers will have kits.
joe francano
07-19-2007 20:19:38
 Re: Either packing or secondary relief in reply to Roger (Mi), 07-19-2007 05:26:59
Thanks for the information.
I am thinking of trying the seal kits from Equipment Parts in Casper, WY. Will they be the same quality as the ones from Case themself?
Thanks.
Roger (Mi)
07-20-2007 03:50:09
 Have had good luck with aftermarket kits in reply to joe francano, 07-19-2007 20:19:38
I've used aftermarket seal kits, and they work as well as the Case kits. Case is very competitive on their seal kits and hydraulic pumps. Since I have a Case industrial dealer within 20 miles (South Bend), I buy most of my backhoe parts there.
