Start with simple things first
Roger (Mi)
06-16-2007 17:04:47
Is the oil level full in the torque tube where the converter is located? Oil filter in front of the radiator clean? What are the torque converter pressure readings? Pressure should be 170-190 PSI. Is the pressure regulator plunger free in the bore? (located near the valve spools) If all else fails, you may want to consider purchasing a repair manual from a Case Industrial dealer. They have hefty price, but believe me, it's worth every penny. Yes, I have one.
