Should NOT be related
Roger (Mi)
06-09-2007 03:53:54
The replacement of a manual clutch should NOT be directly related to the shuttle popping out of forward or reverse. It's likely the new clutch grabs harder and puts greater strain on the detent ball and rail (which holds the shuttle in gear) and that is causing it to pop out. You'll need to remove the shuttle cover and inspect and test the tension on the detent ball and shuttle shift rail.
