case 580ck 1968
mott meeks
06-08-2007 18:21:26
hay out there i have this 1968 580 ck witch has run great for years it now poping out of gear when i move the shuttel shifter in to forward or reverse i recently hah a new cluch put in could this be related.
Roger (Mi)
06-09-2007 03:53:54
 Should NOT be related in reply to mott meeks, 06-08-2007 18:21:26
The replacement of a manual clutch should NOT be directly related to the shuttle popping out of forward or reverse. It's likely the new clutch grabs harder and puts greater strain on the detent ball and rail (which holds the shuttle in gear) and that is causing it to pop out. You'll need to remove the shuttle cover and inspect and test the tension on the detent ball and shuttle shift rail.
Jim B.
06-08-2007 21:01:10
 Re: case 580ck 1968 in reply to mott meeks, 06-08-2007 18:21:26
My experience has been that the best trouble-shooting method is to first consider the latest repair or maintenance done to the any machine.
Good chance something may have been done wrong or something left out during the clutch-job that now causes it to pop-out of gear.
Sorry I don't have an actual suggestion as to what to look for... need more info about your 580CK.
Is it a Power Shuttle or a Manual Shuttle, reverser? Since you said you did a clutch-job I suspect it's a Manual Shuttle, which has conventional (manual) friction clutch. The Power Shuttle CK has a torque converter.
With more info about your CK, including it's usage and condition, perhaps there will be more feedback as to what to look for.
mott meeks
06-09-2007 14:31:50
 Re: case 580ck 1968 in reply to Jim B., 06-08-2007 21:01:10
thanks rodger and jim the tractor has a clutch and is used around a small farm it showed no previous simtons and has run well for years however it does not work to hard or to often.
