Get a repair manual at a farm store
Roger (Mi)
05-31-2007 02:58:03
Since the rearend in a 580B is the same as 430-530 Case agricultural tractors, you can get a 430, 530, 630 tractor repair manual at most farm stores. Follow its instructions. The back lash between the pinion shaft and ring gear is .008 of an inch as measured with a dial indicator. That dimension is achieved by adding or removing shims between the left and right side-gear bearing carriers.
