Need to replace the 3 point lift piston seal..
Roger (Mi)
05-11-2007 04:26:32
The rear end is probably 5 gallons or more over filled with hydraulic oil. There is a measuring dip stick on a plug near the driver's seat on the left side. The 90W gear lube is supposed to be at the low mark on that stick. Remove the rockshaft (three point) cover. Remove the piston located in rockshaft cover. Either CaseIH or an aftermarket seal supplier (Martin Fluid and Power) should have the seal. Drain the rear end oil and replace with 90W gear lube.
