66 430 lck fluid fluid everywhere
higg
05-10-2007 20:11:40
I bought a 430 lck when you raise or lower 3 point fluid runs all over from under seat . could you tell me what problem might be and also proper type and proper amount of fluid?is this from being overfilled or bad seals? Thank you in advance your help and opinions are appreciated
Roger (Mi)
05-11-2007 04:26:32
 Need to replace the 3 point lift piston seal.. in reply to higg, 05-10-2007 20:11:40
The rear end is probably 5 gallons or more over filled with hydraulic oil. There is a measuring dip stick on a plug near the driver's seat on the left side. The 90W gear lube is supposed to be at the low mark on that stick. Remove the rockshaft (three point) cover. Remove the piston located in rockshaft cover. Either CaseIH or an aftermarket seal supplier (Martin Fluid and Power) should have the seal. Drain the rear end oil and replace with 90W gear lube.
