Something in the valve train...
Roger (Mi)
05-10-2007 15:14:55
Air or combustion getting back through the air cleaner? You'll need to remove the tappet cover. Look for a stuck intake valve, bent exhaust valve push rod, a broken exhaust valve rocker arm or a broken valve spring. In other words, it's a problem in the valve train. If it's a stuck valve, use WD40 on the offending valve stem and tap with a light hammer. Eventually, it will free up. Good luck.
