580CK Air Cleaner
PTim
05-10-2007 13:59:06
I have a '66 580CK gas that I ran for about an hour last night and then shut it off. Started it back up about 10 minutes later and it won't start and oil comes gurgling and splattering out of the air cleaner. Before I start tearing it apart I just wanted to know if anyone had experienced this before or had an opinion since you all probably have more experience with this stuff than I do.
Thanks,
Tim
Roger (Mi)
05-10-2007 15:14:55
 Something in the valve train... in reply to PTim, 05-10-2007 13:59:06
Air or combustion getting back through the air cleaner? You'll need to remove the tappet cover. Look for a stuck intake valve, bent exhaust valve push rod, a broken exhaust valve rocker arm or a broken valve spring. In other words, it's a problem in the valve train. If it's a stuck valve, use WD40 on the offending valve stem and tap with a light hammer. Eventually, it will free up. Good luck.
