Brake plate has a phillips head screw holding it.
Roger (Mi)
04-08-2007 16:36:19
After removing the brake housing, you'll find a large phillips head screw holding the brake plate/pinion bearing holder in place. When the screw is removed, the brake plate/pinion bearing holder will come out. After replacing the seal, use care when putting the brake plate/pinion bearing holder back into the housing. There is a sharp edge on the pinion shaft that can destroy your new seal. Wrap a thin piece of tin around the pinion shaft to protect the seal, then pull it out after the brake plate/pinion bearing holder is back in place.
