Replace the rock shaft piston seal.
Roger (Mi)
02-12-2007 04:13:37
The piston seal on the 3 point lift is defective. Remove the rockshaft cover, remove the piston, and replace the piston seal. Hydraulic oil from the torque tube has transferred into the rearend. The rearend should have 90W gear lube. Obviously, its over full and diluted with hydraulic oil. Drain the extra oil out of the rearend and bring it down to its proper level. Do not use it for heavy work until you've replaced all of the diluted oil.
