PTO removal not the problem....
Roger (Mi)
01-19-2007 04:56:28
Hydraulic oil getting into the rearend will be caused by a defective 3 point piston seal. You have plugged the only other possible way for hydraulic oil to get there. If you are using the 300 for heavy work, you need the proper lube oil in the rearend which is 90W gear oil. Also, by removing the home made plug to allow the oil to move back to the torque tube as a cure will cause other problems. The ultra high level of oil in the rearend will put undo pressure on the brake seals and axle seals causing them to seep. Save yourself from more problrms. Remove the rockshaft cover and replace the 3 point piston seal. Return the rearend lube to its proper type and level.
