Make a tool.
Roger (Mi)
01-15-2007 17:24:59
I've had the best luck by using a makeshift tool. Use a piece of flat stock 1/8" thick, 2" wide, and 1' long. Taper one end about 3" from one end to a gradual point. Insert the tool from the side and tap if necessary to get it between the fork/rail and rail casting in the cover. Bend the tool if necessary to get the proper position. Move it back and forth. Try it from both sides. The stuck fork/rail should move into a neutral position, then the cover can be removed. The stuck rail/fork has gone under the rear portion of the transmission housing openning. That's why the cover doesn't come up much at the rear.
