If it's a 530, the gas engine will be 159 CID.
Roger (Mi)
12-10-2006 06:14:11
The 430 gas is 148 CID, 530 gas is 159 CID, and the 630 gas is 188 CID. There should be a tag on the engine. The procedure for splitting any of them is basically the same. Splitting is obvious. Block up the transmission near the bell housing, put a floor jack under the engine (use a couple of wood blocks between the front casting and axle to keep the engine from tipping), remove the wires, linkage, gas line, remove the wish bone bolts, remove the starter, remove the bell housing bolts, and push it apart. If you have the old stamped steel throwout fork, replace it with the upgraded fork. It's still stamped steel, but it's stronger.
