case 530 gas getting to the throw out fork to fix
john mchugh
12-09-2006 17:44:29
how do i go about splitting the tractor to fix what ever is wrong with my clutch
Old Magnet
12-10-2006 20:59:07
 Re: case 530 gas getting to the throw out fork to in reply to john mchugh, 12-09-2006 17:44:29
If it's a 530 series it will either be a 159 gas engine or 188 cu. in. diesel. The serial number tag is located on the rh side of the block under the starter and just behind the end of the oil filter.
john mchugh
12-09-2006 17:46:33
also how do i tell if it is a 530 or not the plate tag next to insterment panel is missing
630crazy
12-10-2006 11:55:26
 Re: case 530 gas getting to the throw out fork to in reply to john mchugh, 12-09-2006 17:46:33
The 630 has 36 inch rims, the 530 has 28s. The 630 also has risers on the bottom of the fenders where they bolt to the axle housing. Their are some other little things too, but those are the easy to spot.
Roger (Mi)
12-10-2006 06:14:11
 If it's a 530, the gas engine will be 159 CID. in reply to john mchugh, 12-09-2006 17:46:33
The 430 gas is 148 CID, 530 gas is 159 CID, and the 630 gas is 188 CID. There should be a tag on the engine. The procedure for splitting any of them is basically the same. Splitting is obvious. Block up the transmission near the bell housing, put a floor jack under the engine (use a couple of wood blocks between the front casting and axle to keep the engine from tipping), remove the wires, linkage, gas line, remove the wish bone bolts, remove the starter, remove the bell housing bolts, and push it apart. If you have the old stamped steel throwout fork, replace it with the upgraded fork. It's still stamped steel, but it's stronger.
Kevin5456
12-09-2006 19:34:43
What is the serial number?
john mchugh
12-10-2006 16:31:23
 Re: case 530 gas getting to the throw out fork to in reply to Kevin5456, 12-09-2006 19:34:43
where on the engine are the serial numbers and how do i tell the engine size from them
