Maybe A Better Explanation
Dick L
01-01-2008 17:30:51
After thinking about the details and connecting it to your question of (Why the governor gear needs to be timed) The magneto has a stop post that catches the pawl that will hold one end of a clock spring. This spring is released to spin the rotor just as the magneto/distributor drive passes the horizontal position. This causes the rotor to produce the electricity to cause spark to the plug. The clock spring has to be released at the horizontal at TDC to be able to start the tractor. Looking at the other mechanical parts of a magneto you could make a case that it could be set to fire on TDC with the magneto/distributor drive in any position if you are not looking for the internal electricity needed to be produced at the proper time on start up.
To it sum up: The clock spring must be released at the exact time you need spark to the spark plug or the engine will not start.
