Should Have Also Said
Dick L
09-20-2007 12:49:45
If you have mics you should put the bearings in the rod and tighten the bolts and mic the inside of the bearing diameter and check it against the crankshaft diameter. That gives you the information you need to properly shim. If you don't have mics you have to add shims until it is not tight and then check with plastigage.
