If You Have One
Dick L
08-13-2007 17:03:57
Look on the right side under the seat. You will see a block that is held in place with three bolts. To hook up a loader you remove that block/cover and place a special block under that cover. That block is drilled and taped for a pressure line and a return line. This block came with the loader. I used the loader and a blade at the same time and I never had a sluggish problem.
I did not install a backhoe on it. I bought a backhoe. The backhoe was a 580 Case. At that time I did not need the loader on the small tractor.
I have three Gleaner E Combines and have had them for years.
cadet trooper
08-14-2007 16:51:56
 Re: If You Have One in reply to Dick L, 08-13-2007 17:03:57
Dick L, I stand corrected, sorry about that but I was referring to the newer generation Gleaners that use the main Hyd. pump to power the steering instead of a belt drive from the crankshaft so I guess if you have a belt drive including its own resevoir it's not a problem. That's why I put in a disclaimer because I haven't been around it for many years.
Additionally a backhoe I know takes a lot of gpm unlike the 3pth because the cylinders require a lot of volume in a hurry which I'm guessing you wouldn't be using the steering while operating the hoe I'm just questioning the gpm of that pump to handle the volume. My pump has a stamp that says 1.0 GPM which is pretty weak.CT
