No Such Gasket
Dick L
05-17-2007 09:14:52
The final drive bolts directly to the transmission metal to metal. You will have pinion shaft seals in the transmission and the final drive also a gasket to the outter plate under the pinion shaft cover.
third party image
The seal you see at the far top/ left actually installs to the right on the inside of the final drive and seals on the large diameter of the pinion shaft left of the pinion gear.
