40 AC B axle seal
Randy Knowlton
05-17-2007 08:57:07
Does anyonone have a part number for the seal where the rear axle bolts to the tran / differential housing on a 40 B?
thanks in advance,
Randy
Randy Knowlton
05-18-2007 14:26:10
 Re: 40 AC B axle seal in reply to Randy Knowlton, 05-17-2007 08:57:07
Thanks, you guys are great!
Randy
Pappy
05-17-2007 21:54:59
This seal is 2 inch OD and 1.250 ID. It is a Napa seal Number 12456. Napa had them in stock.
steve(ill)
05-17-2007 15:33:03
i used a CR 12458 per my old records. this is installed into the differential carrier that bolts to the differential case and preloads the differential bearings. the final drives just slide thru the seal and have 4 bolts to hold each on. there is also a seal inside next to the brake if you are trying to keep the gear lube inside the FD case. the first seal keeps the trans fluid inside that case.
Randy Knowlton
05-17-2007 10:14:11
I realize there is no gasket, but thanks to your diagram I see there are two SEALS not one as I had thought. Do you know of an aftermarket part number to replace these SEALS?
Thanks
Dick L
05-17-2007 11:38:18
 Re: 40 AC B axle seal in reply to Randy Knowlton, 05-17-2007 10:14:11
The aftermarket supplier I use used to be called Detroit ball. I would have to look thru old invoices to find there name they use now. If I dont have a bearing or seal in hand at the time I want to order I just call Sandy Lake in PA. I let the supplier worry about numbers. I only worry about the dimension"s. That is what they have parts books and lists for.
Dick L
05-17-2007 09:14:52
 No Such Gasket in reply to Randy Knowlton, 05-17-2007 08:57:07
The final drive bolts directly to the transmission metal to metal. You will have pinion shaft seals in the transmission and the final drive also a gasket to the outter plate under the pinion shaft cover.
third party image
The seal you see at the far top/ left actually installs to the right on the inside of the final drive and seals on the large diameter of the pinion shaft left of the pinion gear.
