OR, OR, OR
Dick L
01-02-2007 08:42:35
You can do as we do here when making engineering changes to molds and a bolt has to be moved to make that change. Drill it out and tap it to a larger bolt size, place the larger bolt in the hole, cut it off flush, drill the new correct hole and tap it in place. We use an insert much like the one listed below on our machines to clamp molds onto the platens. The inserts we use are installed with an Allen wrench.
