Not Necessarily
Dick L
12-24-2006 14:25:10
If the pump is wore into the cover some it will not suck air into the system to allow the oil to drain back down into the pan. It will spin without pushing all the oil thru the pump. I have seen the same thing happen when some have rebuilt or at least re gasketed the pump and put the thick gasket under the cover rather than the thin one. I have no idea the exact problem with this tractors oil pressure but the pump would be a place to start after the engine is unbolted from the torque tube. If it is not the pump it will still have to be removed before the cam is pulled out to check the cam bearings. What ever is decided it will not be good to continue to run it with out oil pressure.
