Chech Your Filter First
Dick L
12-24-2006 06:47:23
Look at the pictures below if the filter is not the problem. You must have the proper gasket under the pump cover when rebuilding the oil pump.
third party image
third party image
The cover on the right is in need of resurfacing. The cover on the left has been resurfaced.
I have found the check ball in the stem to be rusted with pits and needed to be replaced. The spring is sometimes rusted and weak.
If they pump at all I have not found the vanes or vane springs to be bad. That does not mean the the vanes in your pump is not a problem. They always need to be checked.
