Question??
Dick L
11-07-2006 08:40:51
If and I say (IF) you do not have excessive play, why would you remove the complete front pedestal from the engine??
If you jack up the front of the tractor and can move the front wheels back and forth some and not move the arm all you would need to do is remove the four bolts at the base and remove a shim. Not knowing where the leak is you are wanting to fix could mean you would have to remove it from the engine.
third party image
third party image
Loose wheel bearings can cause the front wheels to wobble as well as a need to remove a shim or two between the upright pedestal and the front casting. I have shimmed under the gear to tighten up the play when the shims had been remove. When doing this you need to check close the steering right to left for binding. When shimming the gear, it sometimes only had real bad wear in the center and will not turn the full distance after re assembly. At that point you would need new or good gears.
