Hey Old.
Dick L
08-21-2006 14:06:10
The B has a taller bull gear in the final drive. I dont remember off hand the number ot teeth each have but the B will move faster if tire size and RPM"s are the same. The tire size makes the difference in ground speed. I have one of my B"s on old 9X24"S and two others on 11.4X24"s. The B should pull 2 14 inch bottom on short tires real easy. 2 12 inch easyer yet. Just takes more weight. Dad farmed 148 acres with a Allis Chalmers C pulling a 2 14inch bottom pull type plow in heavy ground. It was on 10 inch rubber fully loaded with two sets of rear weights and a set of engine side weights. The B on 8 or 9 inch rubber and weighted down should do the same. Like you said same engine and same transmission. You would just need to match the ground speed to the C.
