starting proceedure?
Josh Hoffman
11-25-2005 15:02:28
My tractor has a foot throttle (not hand)...When starting, I have always just pulled the choke, hit the starter & let the choke go, this has always worked fine...should I be giving it some throttle??? I know this is what my manual says, but, I have never done that on this machine before...
BCnT
11-25-2005 18:05:09
 Re: starting proceedure? in reply to Josh Hoffman, 11-25-2005 15:02:28
did the hard starting prob start before or after you did all the work??? try starting it without using choke...sounds like its running way to rich on first start...i got a '62 ford 2000 that i been working on since it was new...i dunno whats up with carb its just always had a leak internally...just enuff to make it flood real easy.
also pull air cleaner hose off before you try to start it...check carb for excess gas when you do.
