help...won't start...
Josh Hoffman
11-25-2005 14:39:13
I hope no one gets mad, I own a 38 Allis WC, but, I am having trouble w/ my Ford Loader tonight, I'm looking for ideas...I've got a 64' Ford series 4000/ model 4140 Industrial Loader w/ a 4 cyl gas motor. It has been getting hard to start in cold weather (runs great once started). I just gave it a good tune-up (new ignition parts/ cleaned carb-installed rebuild kit)...now, I am getting a GREAT spark (snapping blue)....I know I'm getting fuel to the cylinders because when I take the plugs out, they are soaked in gas...but, she is VERY hard to start....My carb has 2 needles to adjust, I followed the manual & have the main adjusting needle 1 & 1/8 turns out & I have the idle air adjust 1 turn out....I'm @ my wits end...Like I say, once I get her going, she'll work all day w/out hesitation...help.
Josh Hoffman
11-25-2005 15:02:28
 starting proceedure? in reply to Josh Hoffman, 11-25-2005 14:39:13
My tractor has a foot throttle (not hand)...When starting, I have always just pulled the choke, hit the starter & let the choke go, this has always worked fine...should I be giving it some throttle??? I know this is what my manual says, but, I have never done that on this machine before...
BCnT
11-25-2005 18:05:09
 Re: starting proceedure? in reply to Josh Hoffman, 11-25-2005 15:02:28
did the hard starting prob start before or after you did all the work??? try starting it without using choke...sounds like its running way to rich on first start...i got a '62 ford 2000 that i been working on since it was new...i dunno whats up with carb its just always had a leak internally...just enuff to make it flood real easy.
also pull air cleaner hose off before you try to start it...check carb for excess gas when you do.
