That might work on a C
Dick L
11-01-2005 12:54:09
I have a doxen or so C wheel centers. I will hold one up and see what it looks like. The bolts would carry the weight rather than the axle flange but that should not be a problem with that small of a tractor. When you drive over a stone or something with a spacer ring the lift on that side of the tractor is still on the axle flange. The bolts just hold the wheel solid to the axle. With two wheel centers bolted togather the lift would be on the bolts. Like I stated that should not be a problem on a light tractor. I have a spacer on my 9523 to keep the tire chains from slapping the fenders and I used it with a loader for several years and the bolts had to take the weight. I broke two bellhousings but never a wheel bolt.
Eldon (WA )
11-01-2005 17:17:53
 Re: That might work on a C in reply to Dick L, 11-01-2005 12:54:09
There are also 4 holes right outside the hub....maybe just bolt another hub on there with some pipe spacers long enough to clear the lug bolt heads.
jason hinds
11-01-2005 14:37:20
Let me know what that looks like and what your opinion is once you have lokkded at the centers back-to-back. I appreciate everones help on this. Using duals will help on the pressure applied to the ground. The lawn may look a little nicer with the duals on...I'm thinking (as far as the rear goes) it would lessen the weight or psi applied to the lawn by the tractor. Plus it would look cool.
Jason
