Thought About It Saturday
Dick L
11-01-2005 10:39:42
When I was draging with my one B. I didn"t have a problem pulling the big drag as far as HP but it does a lot of spinning and jumping in second gear.
third party image
wdtom
11-01-2005 17:58:16
 Re: Thought About It Saturday in reply to Dick L, 11-01-2005 10:39:42
Do you have any weight on the rear of the tractor? I have experienced a few such tractors and they have had to have loaded tires to get the power to the ground. Of course wheel weights would work too. With two or three hundred lbs on each wheel it will act a lot different, maybe better than duals too.
jason hinds
11-01-2005 23:14:23
 Re: Thought About It Saturday in reply to wdtom, 11-01-2005 17:58:16
I do not have any weights or fluid in the tires.
wdtom
11-02-2005 17:32:55
 Re: Thought About It Saturday in reply to jason hinds, 11-01-2005 23:14:23
Well I think your problem would go away if you put several hundred lbs. on or in each wheel. And the tractor won't be so wide. I like a fairly wide tractro for stability,but duals might over do it. Set the rims out on the wheel a bit. Load the tires, or put a few weights on each side. Or both.
Jerry(mo)
11-02-2005 09:10:58
his name is Dennis Anderson on the other forum that when I type the name I can not reply
Eldon (WA )
11-02-2005 11:47:55
 Re: Thought About It Saturday in reply to Jerry(mo) , 11-02-2005 09:10:58
Of course that's a model CA with power adjust rims so the C would be totally different.
Jerry(mo)
11-02-2005 12:29:36
 Re: Thought About It Saturday in reply to Eldon (WA ) , 11-02-2005 11:47:55
sorry I have a wd45 and didn't know the difference. Thought the C and CA were about the same
Jerry(mo)
11-02-2005 09:22:55
">Link
">Link
">Link
Link loading="auto" style="width:auto;height:auto" alt="Third Party Image">
jason hinds
11-02-2005 19:00:07
 thanks for the pictures Jerry in reply to Jerry(mo) , 11-02-2005 09:22:55
Thanks for the pictures Jerry. I do not have power adj rims but I think I have gotten some pretty good ideas here. Adding weight is not realy an option, this tractor is used for wowing my 4+ acre lawn and barn lot I dont want the extra weight to make sink marks or ruts in the yard. I Just got it home yesterday. I was like a boy on christmas morning! Grining from ear to ear. It was great. The little c is so much easier to stear than my 8N it was a pleasure to drive. The deck cut realy good and even. My riding lawn mower was wearing a big frown. I think it realized that its life will probably be spent in the back of the Morton building now that I have the C. Sorry for the long post.
Thanks for all the posts and ideas on the duals.
JAson
