Do I need to pull the carb off again
Dick L
10-28-2005 10:59:23
Do I need to pull the carb off again and clean out, or just get the rest of the gas out of it?
Water droplets seem to get hung up between the main jet and around the bottom of the discharge tube and cause problems. It might speed things up for you to pull the carburetor off and blow it out good. I would screw out the main jet when you blow it out. Optional whether you remove the discharge tube or not. If you have had it out when you worked on the carburetor it would be an easy task. If you drain the bowl from the bottom of the carburetor, at the bottom of the discharge jet is the only void that will hold water droplets.
