Along with 2 fuel tanks
Dick L For Info
10-25-2005 13:12:57
From the factory it would have a heat retainer on the manifold and the pistons would have been shorter for lower compression.
third party image
Gary R
10-25-2005 15:38:32
 Re: Along with 2 fuel tanks in reply to Dick L For Info Only, 10-25-2005 13:12:57
Hood has had a tank attach to it at one time , and shutoff on big tank has two lines to it one has been crimp off. Serial number on tractor and motor show it is a 1940 . Manifold looks to be a gas. Thanks for information . Gary R.
Dick L
10-25-2005 16:24:09
 You Would See in reply to Gary R, 10-25-2005 15:38:32
You would see no difference in the manifold if the heat retainer had been removed. If it was over hauled it would most likely not have the short pistons. I have bought two B"s that were all fuel. One had the tank and the other one did not. Both had the heat retainer removed. One had short flat top pistons and the other one had crator pistons. The pistons were the 3 1/4" diameter. I still have the pistons out here for show and tell, as well as the hood with the small tank.
