SORRY GUYS
Dick L
10-21-2005 13:41:15
Liquid seeks its own level. The gas tank is above the valve heads. I have found gas in the crank case several times from a leaking float valve. Happened to one of my Allis C"s and my Oliver 1650 as well as one of my Oliver 1850"s. If the flow is greater than the weep hole in the bottom of the carb or the weep hole is plugged with crud, the gas will fill the breather, manifold and run into the engine thru on of the open valves and down around the rings. That is if there is enough gas in the tank.
Sid
10-21-2005 19:24:51
 Re: SORRY GUYS in reply to Dick L, 10-21-2005 13:41:15
Well Dick L. I guess I should thought a little more about it before I replied last night. I have never seen or heard of that happening. But I can plainly see how it can happen now.
