I'm Just Guessing But
Dick L
10-16-2005 16:46:09
If the switch is loose you might have found your problem. I would pull the starter out and tap a larger thread. On the starter holding stud and jam nut, Get a box wrench the correct size for the jam nut and whack it with a hammer to break it loose. To get the stud out get a BIG screw driver. One that fits the slot, not some little dinky thing, best with a square shank that you can put a small wrench on. Then push in as hard as you can while turning it out. Tap it a few times on the end before trying to turn it out. Tap not beat. I have removed them when someone had already messed up the slot by using a punch and hammer to unscrew them.
