Butch... what would you suggest...
Dev Emch
10-01-2005 10:42:45
Hi Butch...
Nice shots. So why do you think these heads are like this? What improvements would you suggest to remedy this from happening?
I make my own patterns and work on machine restoration work in my private time. If this becomes an issue, I will simply build a new set of patterns and core boxes and have a new head cast. So there is an opportunity to rememdy the design flaws by going down this path.
And I do have metal planers, metal shapers, milling machines and lathes including LeBlonds, Hardinge, Kearney trecker, Brown & Sharpe, Bridgeport, etc. So the machine work is not the issue. The new design and pattern work is the issue and does take time. But if its needed, well then, its needed.
Dev
