Little more help needed (of course)
farmerwannabe
09-24-2005 11:45:27
Thanks for all the insights and pictures everyone. The bowl I purchased is like the ones in the pictures....the only problem is the one I took off is NOT. The extension is needed on this tractor, but the tube/extension I have is way different....it actually screws INTO the top of the sediment bowl and then into the tank. Not sure where I can find a proper one. Anyone have one not being used?
Another problem: the fuel line from the bowl to the carb. isn't hard on our B. Instead, it's a regular rubber hose that's in bad shape. I was just going to replace it with another rubber one, but with my having to use this new, wider, bowl at a different angle (the one I took off was running perdindicular with the tank, with the petcock in the back), should I go with a hard line because of the 90 degree turn? What do I seal the threads with to prevent a leak on the tank/bowl? Thanks again!
