What does it do if you choke it while throttling u
ScooterBuck
09-20-2005 17:36:50
If that does not affect it (help it run a little better) your problem might be ignition. But I'm guessing it could be something in fuel tank, line, carb.... Also like mentioned there could be a manifold leak. Spray carb cleaner around manifold at an idle and see if the idle drops. If it does you have a leak there. It can also leak stright in from the exhaust part of the manifold. I'd start with the fuel system though. Feed the carb from a known clean tank (container) bypassing strainer. If it runs ok that way you know you have a problem in the line or tank. Rusty tanks seem to be a big problem.
