WD shuts off when throttle opened
Ron Nickels
09-20-2005 08:23:54
I just completely overhauled my WD engine. It purrs like a kitten at idle and up to about half throttle. When you open the throttle to about half the engine shuts down. Does anyone have an idea?
souNdguy
09-22-2005 21:15:28
 Re: WD shuts off when throttle opened in reply to Ron Nickels, 09-20-2005 08:23:54
Any chance it is too rich? try lenaing it 1/8 of a turn and check.. If you can lean it and keep it from dieing, without reducing power too much or making it stumble, you have it made.
Soundguy
Kent of SW MO
09-21-2005 05:47:21
Is it magneto or battery ignition? If battery check coil polarity. The point lead should be connected to the positive of the coil if the battery is positive ground which is stock. If tractor has been converted to 12 volt negative ground as when an alternator is installed the point need to be connected to the negative terminal of the coil. If you are 12 volt negative ground Pertronix (sp?) has a solid state replacement for the points and condenser on your 4 banger. I am using one of theie units on the G-262 power unit on my C-II Gleaner.
Kent
BCnT
09-20-2005 09:51:14
does it start right back up or do you have to wait awhile before it will start? kinda sounds like its running out of fuel due to a clogged filter or screen only allowing enuff fuel for partial throttle
Ron Nickels
09-20-2005 11:53:13
 Re: WD shuts off when throttle opened in reply to BCnT, 09-20-2005 09:51:14
Yes, it starts back immediately. As a matter of fact, if you quickly push the throttle back to idle then it recovers.
ScooterBuck
09-20-2005 17:36:50
 What does it do if you choke it while throttling u in reply to Ron Nickels, 09-20-2005 11:53:13
If that does not affect it (help it run a little better) your problem might be ignition. But I'm guessing it could be something in fuel tank, line, carb.... Also like mentioned there could be a manifold leak. Spray carb cleaner around manifold at an idle and see if the idle drops. If it does you have a leak there. It can also leak stright in from the exhaust part of the manifold. I'd start with the fuel system though. Feed the carb from a known clean tank (container) bypassing strainer. If it runs ok that way you know you have a problem in the line or tank. Rusty tanks seem to be a big problem.
BCnT
09-20-2005 16:01:06
 Re: WD shuts off when throttle opened in reply to Ron Nickels, 09-20-2005 11:53:13
i'd start looking for a blocked passage in carb high speed circuit or maybe an intake leak...somethings causing it to run real lean and die.
ebbsspeed
09-20-2005 18:52:50
 Re: WD shuts off when throttle opened in reply to BCnT, 09-20-2005 16:01:06
Likely a high-speed circuit problem in the carb. Doubt it's a vacuum leak because those are usually more troublesome at low speeds. Did you by cut out any of the gaskets yourself? I'm not familiar with the WD's carb, but on my Harley there is one gasket between the air cleaner and the carb that has a small air-bleed hole in it that cannot be blocked. Ask me how I know.....
