Thanks. This helps. Update.
Dev Emch
09-20-2005 14:29:41
Thanks. This helps out. I did find a loader I like and its the TS=1000 loader made by Henry. I think its equal to an industrial backhoe loader and it even suggests using a mark IV hoe with this loader. The book says it can lift 3000 pounds to about a 10 foot dumping height.
I am using this book and its few limited pictures as a guideline for designing and building mine. Not having seen one in person and not having the engineering drawings, it makes things a little harder to visualize.
The tapered box beams are cool but they take extra effort to make if you dont have the equipment to form them. They can be made by resawing structual steel elements on a large bandsaw such as a grob or doall but this is time consuming and tedious. I have reserved myself to doing this but I need to have some idea of how thick to make these elements, hence my questions. This also takes many hours of arc and TIG welding and grinding to get these beams just right and strong enough.
In looking at the current generation of Great Bend loaders, I have to say that I am disappointed. If you look at the loader on a modern Case backhoe, *THAT* is a loader! The others are gas powered tonka toys. I understand why they need to be made light weight but I need to go the other way.
The TS-1000 loader is listed at weighing in at 1652 pounds minus the bucket. The 60 inch bucket weighs an extra 520 pounds.
So this gives you an idea of where I am comming from. What are the dimensions on the arms of your industrial loader? What about the pillars? How big are they and what is the gage of steel used to make them?
The design also looks streamlined and the word I used to describe it cannot be used on this forum. But it the loader does look good.
Thanks in advance...
Dev
Joe(TX)
09-21-2005 10:16:10
 Re: Thanks. This helps. Update. in reply to Dev Emch, 09-20-2005 14:29:41
I will try to get some measurments. It'll be a couple of days.
