IT musta copied page...
BCnT
09-14-2005 22:45:28
i got same instructions in my copy of original...think i'm gonna pull all injectors tomorrow and see what i got...theres a indy dealer in town thats got a test bench and set up to clean/repair if i get in over my head.
appreciate your time/experience
chuck
Texas Denny
09-15-2005 06:47:27
 Re: IT musta copied page... in reply to BCnT, 09-14-2005 22:45:28
Good luck. I just re-read your original post (probably the 5th time). I still think the issue is valves and not injectors. When you get the injectors out, take a compression check. See if all cylinders are about the same.
And maybe there is something the matter with your fuel. I can't imagine dirty injectors causing the trouble you describe. A small amount of gasoline mixed with diesel would cause all the noises you describe. I'd drain your tank, put in new fuel. Drain the filters and replace them and bleed the system. Then start it and see where you are.
