oh yeah,1 other thing
BCnT
09-14-2005 07:12:02
when i pulled the return lines to check for blockage i noticed 2-3 flares were cracked. i dont suppose that line is available anymore? i was thinking brass hose barbs and tee's with rubber fuel hose as a replacement.any problem with using that?
thanx
Texas Denny
09-14-2005 11:48:20
 Re: oh yeah,1 other thing in reply to BCnT, 09-14-2005 07:12:02
Mine leaked at all connections because they hadn't used seamless tubing - they leaked at the seams. I got soft copper seamless and new tees and fittings for compression fittings and replumbed the whole thing. Cost was my driver. I believe these lines may still be available from Allis as I got some other parts from them. If they aren't, I'd use copper. With soft copper, it could be done with a flare system as well. I guess fuel hose line would work if it is rated for diesel fuel. It isn't high pressure. But hose may eventually degrade and I'd be concerned about the breakdown of the materials getting into the system and causing problems.
