Sorry, I had to leave For a Bit
Dick L
08-28-2005 09:05:07
Now, You will not be able to slide the cam out without removing the rocker arm assembly and push rods. With out turning the engine upside down you will have to work with each lifter as you slide the cam back in as they will catch on the cam lobes.
If I was to retime it here, I would remove the engine and turn the block upside down. I do have all the equiptment and it would be easyer and faster. I do not know what you have to work with. If you can"t turn it over, (watch your temper) and you will be able to retime it. Some little blocks of wood might be able to hold all the lifters up at the same time.
