Re:Gatz a c d-17 hydraulic pump
David Jackson
07-28-2005 13:02:40
I had the same problem with my Series IV. On the back right side of the control valves just under the flat peice of metal is a screw. It has two nuts on it. One is normal and the other is rounded on top to cover the screw. Take the top nut off an loosen the bottom one. It will allow you to back the screw out and let the pressure go from the pump. I am not a profesional and this isn't technical language, but I learned it from a good tractor mechanic. Good luck.
