Re:Gatz a c d-17 hydraulic pump
RICARDO6944
07-25-2005 17:53:48
Gatz I had to buy a wrenc for the hex nut. The level was low. For some reason however when put the fluid in I never got any down in the hyd. sump. I ran the tractor a short time to with no results. I then filled the hydraulic sump from the suction pipe after taking it loose at the pump. This worked and I got a good flow from the pump. However now my lift goes up, but will not come down again. The only way it comes down is to turn
the tractor off. then it slowly goes back down. I bought a book and tried adjusting the position and other lever they talk about, but had
no results. If you have had this problem let me know anything you think would work. Thanks, Richard
David Jackson
07-28-2005 13:02:40
 Re:Gatz a c d-17 hydraulic pump in reply to RICARDO6944, 07-25-2005 17:53:48
I had the same problem with my Series IV. On the back right side of the control valves just under the flat peice of metal is a screw. It has two nuts on it. One is normal and the other is rounded on top to cover the screw. Take the top nut off an loosen the bottom one. It will allow you to back the screw out and let the pressure go from the pump. I am not a profesional and this isn't technical language, but I learned it from a good tractor mechanic. Good luck.
