Pulling vs braking.
Steve from MO -
07-05-2005 06:45:05
A WD or WD45, or preferably a D-17 would be a whole lot better to pull a PTO baler. There are lots of reasons for this.
The B is a tough little tractor for its size, but it"s just too small for that baler even with a baler engine. You could pull it ok, but the tractor is not heavy enough to control the baler on the hills.
That"s my story and I"m sticking to it. Your mileage may vary.
Don L C
07-06-2005 18:13:32
 Re: Pulling vs braking. in reply to Steve from MO - dangit!, 07-05-2005 06:45:05
Steve from MO --- is telling it to you right...the tractor should out weight the bailer to be safe.....Don L C from S.W.Ohio
Chad B.
07-05-2005 07:17:46
How much does a WD weigh? Around 4000 lbs?
07-06-2005 07:44:09
 Purdy close. in reply to Chad B., 07-05-2005 07:17:46
Nebraska tests indicated something like that. Maximum pull was with a lot of weight added.
