Thanks Steve(ill) and old....more info for Steve
Mike from Ohio
06-03-2005 20:53:25
I`ll give your suggestions a try. I really appreciate your input.
Steve, to give you a little more detail...I can restart it within a few minutes...But, it seems to be draining my battery (severely)...I mean to the point that it has to be put on a charger or jumped via my truck battery...The battery is less than 7 months old (its NAPA`s best commercial grade battery)...and the restart only lasts a couple of mowing strips...
steve(ill)
06-04-2005 19:01:16
 Re: Thanks Steve(ill) and old....more info for St in reply to Mike from Ohio, 06-03-2005 20:53:25
you are runing out of gas. unscrew the glass bowl holder from the gas tinak. flush the tank, flush the line, drain the carb and flush it. you might have something like a walnut in the gas tank that is plugging the line now and then. if it makes two laps, it is probably not the float. --- since it starts right back up, it is not the coil.--- charge the battery overnight with a electric charger. that should last several hours running and dozen startups.--- to check charge, ground the F terminal on the generator and see if amp meter is full charge. best to put a volt meter across the A and F terminals and see if you get good voltage (with the F grounded). if that dont work, the generator is not working.
